Back to Connectivity
Activate or deactivate flight mode
You can deactivate all wireless connections, so your mobile phone can’t cause any interference with sensitive equipment in a plane or a hospital. You can still use your mobile phone when flight mode is activated, but you can’t send messages or make calls.
1. Activate or deactivate flight mode
Slide two fingers down the display starting from the top edge of your mobile phone.
Press Airplane mode.
Depending on the current setting, flight mode is activated or deactivated.
