Back to Connectivity
You can limit your data usage when abroad by deactivating data roaming. No connection to the Internet via the mobile network when abroad can then be established. You can still use WLAN even though data roaming is deactivated.
1. Find "Mobile networks"
Slide two fingers down the display starting from the top edge of your mobile phone.
Press More.
Press Mobile networks.
If you activate data roaming:
Press OK to confirm.
3. Return to the Home screen
