Back to Settings & usage
Step 1 of 17
Step 2 of 17
Step 3 of 17
Press Lock screen.
Step 4 of 17
Press Screen lock type.
Step 5 of 17
Press Fingerprints.
Step 6 of 17
Press Continue.
Step 7 of 17
Step 8 of 17
Follow the instructions on the display to create the phone lock code using your fingerprint.
Step 9 of 17
Press Done.
Step 10 of 17
Press the required settings.
Step 11 of 17
Press Done.
Step 12 of 17
Follow the instructions on the display to back up your additional phone lock code.
Step 13 of 17
Step 14 of 17
Key in the current phone lock code and press None.
Step 15 of 17
Press Remove data.
Step 16 of 17
Press Remove.
Step 17 of 17
1. Find "Lock screen"
Press Lock screen.
2. Create phone lock code using your fingerprint
Press Fingerprints.
Press Continue.
Press Done.
Press Done.
Press Remove data.
Press Remove.
4. Return to the Home screen
Get information on...
Or select...
Another device
