Samsung Galaxy S8
Back to Settings & usage
1. Find "Lock screen and security"
2. Create phone lock code using iris scanner
Press Iris Scanner.
Press CONTINUE.
Press CONTINUE.
Follow the instructions on the display to create the phone lock code using iris scanner.
Press Screen lock type.
Key in the current phone lock code and press None.
4. Return to the Home screen
