Mobile guides
Connect to a WLAN
Step 1 of 8
Step 2 of 8
Step 3 of 8
Press Connections.
Step 4 of 8
Press Wi-Fi.
Step 5 of 8
Press the indicator until the function is activated.
Step 6 of 8
Press the required WLAN.
Step 7 of 8
Follow the instructions on the display to key in the security settings, if required, and press CONNECT.
Step 8 of 8
1. Find "Wi-Fi"
Press Connections.
Press Wi-Fi.
2. Activate WLAN
3. Connect to a WLAN
4. Return to the Home screen
Get information on...
Or select...
Another device
