Samsung Galaxy S8
You can limit your data usage when abroad by deactivating data roaming. No connection to the Internet via the mobile network when abroad can then be established. You can still use WLAN even though data roaming is deactivated.
1. Find "Mobile networks"
Press Connections.
Press Mobile networks.
3. Return to the Home screen
