Mobile guides
Samsung Galaxy S7
If the WLAN is using a hidden SSID, you won't find the WLAN when searching for available WLANs. You can only connect to a WLAN using a hidden SSID if you know the correct SSID.
Solution: Key in SSID and security settings manually on your mobile phone.
