Customer Center E-Mail + SMS TV myCloud Find a Swisscom shop Contact
Mobile guides
Back to Calls & contacts
Activate or deactivate call barring
You can block certain types of calls such as incoming calls when you're abroad.
Step 1 of 13
Press Phone.
Step 2 of 13
Press MORE.
Step 3 of 13
Press Settings.
Step 4 of 13
Press More settings.
Step 5 of 13
Press Call barring.
Step 6 of 13
Press Voice call.
Step 7 of 13
All outgoing calls
If you select International calls except home, no international calls can be made, but you can still call home when you're abroad.
If you select All incoming calls when roaming, you can't receive incoming calls when you take your mobile phone abroad. Incoming calls will be rejected by the network and the call won't go through.
Step 8 of 13
International calls
Step 9 of 13
Step 10 of 13
All incoming calls
Step 11 of 13
Step 12 of 13
Key in your call barring password and press OK to activate or deactivate the function.
Step 13 of 13
1. Find "Voice call"
Press Phone.
Press MORE.
Press Settings.
Press Call barring.
Press Voice call.
2. Select barring option
All outgoing calls
International calls
All incoming calls
3. Activate or deactivate call barring
4. Return to the Home screen
