Samsung Galaxy S7 edge
Back to Messaging & Internet
Write and send MMS
An MMS is a message which can contain pictures and other media files and can be sent to other mobile phones and e-mail addresses. If you can't send and receive MMS as soon as you've inserted your SIM, you need to set up your mobile phone for MMS.
1. Find "Messages"
Press Messages.
2. Write MMS
Press the new message icon.
3. Select the recipient
Press the required contact.
4. Write the text
5. Insert pictures, video clips and audio files
Press the attachment icon.
Press OTHER.
Insert a picture, go to 5a.
Insert a video clip, go to 5b.
Insert an audio file, go to 5c.
6. 5a - Insert a picture
Press Image.
Go to the required folder.
Press the required picture to select it.
Press DONE.
7. 5b - Insert a video clip
Press Video.
Press the required video clip.
8. 5c - Insert an audio file
Press Audio.
Press the required audio file.
Press DONE.
9. Send the MMS
Press SEND when you've finished your MMS.
10. Return to the Home screen
