Mobile guides
Back to Calls & contacts
Activate or deactivate fixed dialling
When fixed dialling is turned on, you can only call selected numbers and do emergency calls. Incoming calls aren't affected.
Step 1 of 9
Press Phone.
Step 2 of 9
Press MORE.
Step 3 of 9
Press Settings.
Step 4 of 9
Press More settings.
Step 5 of 9
Press Fixed Dialling Numbers.
Step 6 of 9
To activate fixed dialling:
Press Enable FDN.
Step 7 of 9
To deactivate fixed dialling:
Press Disable FDN.
Step 8 of 9
Key in your PIN2 and press OK.
Step 9 of 9
1. Find "Fixed Dialling Numbers"
Press Phone.
Press MORE.
Press Settings.
2. Activate or deactivate fixed dialling
Press Enable FDN.
Press Disable FDN.
3. Return to the Home screen
