Samsung Galaxy S6 edge +
Select a ring tone
1. Find " Ringtone"
Press Sounds and notifications.
Press Ringtones and sounds.
Press Ringtone.
2. Select ring tone
To use one of the phone ring tones:
Once you've found a ring tone you like, press the Return key.
To use one of your own ring tones:
Press Add ringtone.
Press Add ringtone.
Once you've found a ring tone you like, press DONE.
3. Return to the Home screen
