Step 1 of 24
Step 2 of 24
Step 3 of 24
Press Screen lock type.
Samsung Galaxy S6 edge +
Step 4 of 24
You can create several types of phone lock codes. The steps below describe three examples:
Create phone lock code using a pattern, go to 2a.
Create phone lock code using your fingerprint, go to 2b.
Create phone lock code using a PIN, go to 2c.
Step 5 of 24
Press Pattern.
Step 6 of 24
Press and drag a point to connect at least four points.
Step 7 of 24
Press CONTINUE.
Repeat the selected phone lock code to confirm.
Step 8 of 24
Press CONFIRM.
Step 9 of 24
Key in a four-digit PIN and press CONTINUE.
Step 10 of 24
Key in the PIN again and press OK.
Step 11 of 24
Press the required setting.
Step 12 of 24
Press DONE.
Step 13 of 24
Press Fingerprints.
Follow the instructions on the display to add a fingerprint.
Step 14 of 24
Key in a password and press CONTINUE.
Step 15 of 24
Key in the password again and press OK.
Step 16 of 24
Step 17 of 24
Press DONE.
Step 18 of 24
Press PIN.
Step 19 of 24
Key in the required phone lock code and press CONTINUE.
Step 20 of 24
Key in the phone lock code again and press OK.
Step 21 of 24
Step 22 of 24
Press DONE.
Step 23 of 24
Press None.
Step 24 of 24
1. Find " Screen lock type"
2. Select option
3. 2a - Create phone lock code using a pattern
Press Pattern.
Press CONTINUE.
Press CONFIRM.
Press DONE.
4. 2b - Create phone lock code using your fingerprint
Press Fingerprints.
Press DONE.
5. 2c - Create phone lock code using a PIN
Press PIN.
Press DONE.
6. Deactivate use of phone lock code
Press None.
7. Return to the Home screen
Get information on...
Or select...
Another device
