Back to Multimedia & apps
Activate or deactivate GPS
You mobile phone can determine your geographical position using GPS (Global Positioning System). The information about your position is used by a number of applications on you mobile phone, such as navigation, the search function and the weather forecast.
Step 1 of 10
Step 2 of 10
Press Privacy and safety.
Step 3 of 10
Press Location.
Step 4 of 10
Press the indicator next to "Location" to activate or deactivate the function.
Step 5 of 10
If you activate the function:
Press Locating method.
Proceed to step 3.
If you deactivate the function:
Proceed to step 4.
Samsung Galaxy S6 edge +
Step 6 of 10
Activate satellite-based and network-based GPS, go to 3a.
Activate network-based GPS, go to 3b.
Activate satellite-based GPS, go to 3c.
Step 7 of 10
Press GPS, Wi-Fi, and mobile networks.
If you activate satellite-based and network-based GPS, your mobile phone can find your position quickly and with the highest accuracy.
Step 8 of 10
Press Wi-Fi and mobile networks.
If you activate wireless networks, your mobile phone can find your approximate position using the network. This is useful if you don't have a GPS satellite fix.
Step 9 of 10
Press GPS only.
If you activate satellite-based GPS, your mobile phone can find your exact position. Satellite-based GPS requires a clear view of the sky.
Step 10 of 10
1. Find " Location"
Press Location.
2. Activate or deactivate GPS
Proceed to step 3.
Proceed to step 4.
3. Select option
4. 3a - Activate satellite-based and network-based GPS
5. 3b - Activate network-based GPS
6. 3c - Activate satellite-based GPS
Press GPS only.
7. Return to the Home screen
Get information on...
Or select...
Another device
