Back to Getting started
Charge the battery
You should charge the battery in your mobile phone regularly to ensure that your mobile phone is always ready for use.
Step 1 of 3
Connect the charger to the phone socket and to a wall socket.
Step 2 of 3
When the battery charging icon is displayed, charging is in progress.
Samsung Galaxy S6 edge +
Step 3 of 3
When the battery is fully charged, you can remove the charger from the wall socket and your mobile phone.
When your mobile phone is turned on, you can always see the battery power level. The bigger the coloured section of the battery icon, the more power.
1. Connect the charger to your mobile phone
2. End charging
