Mobile guides
Back to Calls & contacts
Create contact
You can save your contacts in your mobile phone's address book. You can save additional information to each contact such as e-mail address and personal ring tone.
Step 1 of 30
Press Contacts.
Step 2 of 30
Press the new contact icon.
Step 3 of 30
Press the drop down list above "Name".
If you select Device, the contact is created in the mobile phone's address book.
If you select SIM card, the contact is created on your SIM.
If you select an account, the contact is attached to this account but is also displayed on your mobile phone.
Step 4 of 30
Press Device.
Samsung Galaxy S6 edge +
Step 5 of 30
Key in the required name.
Step 6 of 30
Press Phone number and key in the required phone number.
If you key in the phone number with a + followed by the country code, you can also call contacts in the address book when you're abroad.
Step 7 of 30
Press the field next to the phone number.
Step 8 of 30
Press the required number type.
Step 9 of 30
Press Email and key in the required e-mail address.
Step 10 of 30
Press the field next to the e-mail address.
Step 11 of 30
Press the required e-mail type.
Step 12 of 30
You can add more information to the contact. The following steps show two examples:
Assign picture, go to 7a.
Assign ring tone, go to 7b.
Step 13 of 30
Press the add picture icon.
Step 14 of 30
To take a new picture:
Point the camera lens at the required object and press the camera icon to take the picture.
Step 15 of 30
To assign a saved picture:
Press the picture icon.
Step 16 of 30
Go to the required folder.
Press the required picture.
Step 17 of 30
Drag the frame to the required position to select the required detail.
Step 18 of 30
Press DONE.
Step 19 of 30
Press ADD ANOTHER FIELD.
Step 20 of 30
Press Ringtone.
Step 21 of 30
Press Ringtone.
Step 22 of 30
To assign your mobile phone's current default ring tone:
Press Default ringtone.
Step 23 of 30
Press the Return key.
Step 24 of 30
To assign one of your mobile phone's default ring tones:
Step 25 of 30
Once you've found a ring tone you like, press the Return key.
Step 26 of 30
To assign one of your own ring tones:
Press Add ringtone.
Step 27 of 30
Step 28 of 30
Once you've found a ring tone you like, press DONE.
Step 29 of 30
Press SAVE.
Step 30 of 30
1. Find "Contacts"
Press Contacts.
2. Create contact
3. Select address book
Press Device.
4. Enter name
5. Enter phone number
6. Enter e-mail address
7. Add more information
8. 7a - Assign picture
Press DONE.
9. 7b - Assign ring tone
Press Ringtone.
Press Ringtone.
Press Add ringtone.
10. Save contact
Press SAVE.
11. Return to the Home screen
