Samsung Galaxy S6 edge +
Back to Calls & contacts
Answer a call
When you receive a call, you can either answer it, reject it or silence the incoming call alert.
1. Select an option
Answer call, go to 1a.
Reject call, go to 1b.
Silence the incoming call alert, go to 1c.
2. 1a - Answer call
Press and drag the accept call icon right.
3. 1b - Reject call
Press and drag the reject call icon left.
When you reject a call, the caller will hear a busy signal or be diverted to COMBOX®.
4. 1c - Silence the incoming call alert
Press the Top volume key or the Bottom volume key when you get a call.
The incoming call alert is silenced without the caller hearing it, and the call continues until it is ended or diverted.
