Connect to a WLAN
Step 1 of 7
Step 2 of 7
Press the Connections tab.
Step 3 of 7
Press Wi-Fi.
Step 4 of 7
Press the indicator next to "Wi-Fi" until the function is activated.
Step 5 of 7
Press the required WLAN.
Step 6 of 7
Press Connect.
Step 7 of 7
1. Find " Wi-Fi"
Press Wi-Fi.
2. Activate WLAN
3. Connect to WLAN
Press Connect.
4. Return to the Home screen
Get information on...
Or select...
Another device
