Mobile guides
Back to Settings & usage
Step 1 of 15
Step 2 of 15
Step 3 of 15
Press Lock screen.
Step 4 of 15
Press Screen lock type.
Step 5 of 15
Press Fingerprints.
Step 6 of 15
Press Continue.
Step 7 of 15
Step 8 of 15
Follow the instructions on the display to create the phone lock code using your fingerprint.
Step 9 of 15
Press the required settiings.
Step 10 of 15
Press Done.
Step 11 of 15
Step 12 of 15
Key in the current phone lock code and press None.
Step 13 of 15
Press Remove data.
Step 14 of 15
Press Remove.
Step 15 of 15
1. Find "Screen lock type"
Press Lock screen.
2. Create phone lock code using your fingerprint
Press Fingerprints.
Press Continue.
Press Done.
Press Remove data.
Press Remove.
4. Return to the Home screen
Get information on...
Or select...
Another device
