Mobile guides
Back to Select settings
You can avoid data traffic when abroad by deactivating data roaming. No connection to the Internet via the mobile network can then be established. You can still use WLAN even though data roaming is deactivated.
Step 1 of 8
Press Applications.
Step 2 of 8
Press Settings.
Step 3 of 8
Press Wireless and network.
Step 4 of 8
Press Mobile networks.
Step 5 of 8
Press Data roaming to activate or deactivate data roaming.
Step 6 of 8
If you activate data roaming:
Press OK to confirm.
Step 7 of 8
When the box next to the menu item is ticked (V), data roaming is activated.
Step 8 of 8
1. Find "Mobile networks"
Press Applications.
Press Settings.
3. Return to the Home screen
Get information on...
Or select...
Another device
