Samsung Galaxy Note9
Back to Settings & usage
Connect a Bluetooth device to your mobile phone
Bluetooth is a wireless connection which you can use to transfer files between two devices or to establish a connection to other devices, such as a wireless headset or keyboard.
1. Find "Bluetooth"
Press Connections.
Press Bluetooth.
2. Activate Bluetooth
Press the indicator below "Bluetooth" until the function is activated.
Press the required Bluetooth device and follow the instructions on the display to connect the Bluetooth device to your mobile phone.
4. Return to the Home screen
