Mobile guides
Back to Settings & usage
Step 1 of 14
Step 2 of 14
Step 3 of 14
Press Lock screen.
Step 4 of 14
Press Screen lock type.
Step 5 of 14
Press Iris.
Step 6 of 14
Press CONTINUE.
Step 7 of 14
Step 8 of 14
Press CONTINUE.
Step 9 of 14
Follow the instructions on the display to create the phone lock code using iris scanner.
Step 10 of 14
Step 11 of 14
Key in the current phone lock code and press None.
Step 12 of 14
Press REMOVE DATA.
Step 13 of 14
Press REMOVE.
Step 14 of 14
1. Find "Screen lock type"
Press Lock screen.
2. Create phone lock code using iris scanner
Press Iris.
Press CONTINUE.
Press CONTINUE.
Press REMOVE DATA.
Press REMOVE.
4. Return to the Home screen
