Customer Center E-Mail + SMS TV myCloud Find a Swisscom shop Contact
Mobile guides
Activate or deactivate mobile data
You can limit your data usage by deactivating mobile data. No connection to the Internet via the mobile network can then be established. You can still use WLAN even though mobile data is deactivated.
Step 1 of 3
Slide two fingers down the display starting from the top edge of your mobile phone.
Step 2 of 3
Press the mobile data icon to activate or deactivate the function.
Step 3 of 3
1. Activate or deactivate mobile data
2. Return to the Home screen
