Mobile guides
Back to Settings & usage
Step 1 of 13
Step 2 of 13
Step 3 of 13
Step 4 of 13
Press Iris Scanner.
Step 5 of 13
Press CONTINUE.
Step 6 of 13
Step 7 of 13
Press CONTINUE.
Step 8 of 13
Follow the instructions on the display to create the phone lock code using iris scanner.
Step 9 of 13
Press Screen lock type.
Step 10 of 13
Key in the current phone lock code and press None.
Step 11 of 13
Press REMOVE DATA.
Step 12 of 13
Press REMOVE.
Step 13 of 13
1. Find "Lock screen and security"
2. Create phone lock code using iris scanner
Press Iris Scanner.
Press CONTINUE.
Press CONTINUE.
Press REMOVE DATA.
Press REMOVE.
4. Return to the Home screen
Get information on...
Or select...
Another device
