Mobile guides
Samsung Galaxy Note8
If your device, for unknown reasons, gets slow or doesn't work as it usually does, it may help restoring the factory default settings. Please note that the configurations and content you've added to your device yourself may be deleted. We recommend you back up your device first.
Solution: Restore factory default settings.
