Samsung Galaxy Note8
Connect to a WLAN
1. Find "Wi-Fi"
Press Connections.
Press Wi-Fi.
2. Activate WLAN
Press the indicator until the function is activated.
3. Connect to a WLAN
Press the required WLAN.
Follow the instructions on the display to key in the security settings, if required, and press CONNECT.
4. Return to the Home screen
