Mobile guides
Activate or deactivate GPS
You mobile phone can determine your geographical position using GPS (Global Positioning System). The information about your position is used by a number of applications on you mobile phone, such as navigation, the search function and the weather forecast.
Step 1 of 10
Step 2 of 10
Step 3 of 10
Press Connections.
Step 4 of 10
Press Location.
Step 5 of 10
Press the indicator below "LOCATION" to activate or deactivate the function.
Step 6 of 10
Press Locating method.
Step 7 of 10
If you select High accuracy, your mobile phone can find your position quickly and with the highest possible accuracy. Satellite-based GPS requires a clear view of the sky.
Step 8 of 10
If you select Battery saving, your mobile phone can find your approximate position using the mobile network and nearby WLANs.
Step 9 of 10
If you select Phone only, your mobile phone can find your exact position but it may take longer as there is no access to supplementary information from the mobile network or nearby WLANs.
Step 10 of 10
1. Find "Location"
Press Connections.
Press Location.
2. Activate or deactivate GPS
3. Select positioning method
4. Return to the Home screen
Get information on...
Or select...
Another device
