You can limit your data usage when abroad by deactivating data roaming. No connection to the Internet via the mobile network when abroad can then be established. You can still use WLAN even though data roaming is deactivated.
Step 1 of 6
Step 2 of 6
Step 3 of 6
Press Connections.
Step 4 of 6
Press Mobile networks.
Step 5 of 6
Step 6 of 6
1. Find "Mobile networks"
Press Connections.
3. Return to the Home screen
Get information on...
Or select...
Another device
