Samsung Galaxy Note20 Ultra 5G
Back to Settings & usage
Restore the factory default settings
If your mobile phone is slow or in any other way doesn't work or respond as well as it should, it may help to restore the factory default settings. This deletes all configurations you've made in your mobile phone.
1. Find "Factory data reset"
Press General management.
Press Reset.
Press Factory data reset.
2. Restore factory default settings
Press Reset.
Press Delete all and wait a moment while the factory default settings are restored. Follow the instructions on the display to set up your mobile phone and prepare it for use.
