Samsung Galaxy Note20 Ultra 5G
Back to Settings & usage
1. Find "Lock screen"
Press Lock screen.
2. Create phone lock code using your fingerprint
Press Screen lock type.
Press Fingerprints.
Press Continue.
Follow the instructions on the display to create the phone lock code using your fingerprint.
Press Done.
Press the required settings.
Press Done.
Follow the instructions on the display to back up your additional phone lock code.
Key in the current phone lock code and press None.
Press Remove data.
Press Remove.
4. Return to the Home screen
