Samsung Galaxy Note20 Ultra 5G
Back to Getting started
Phone keys and sockets
Follow these instructions for a guide on how to use the phone keys and sockets.
1. The Side key
Several functions are associated with the Side key:
Press the Side key to turn on your mobile phone.
Press the Side key to activate the screen lock.
Press the Side key to open the Bixby menu.
2. Fingerprint sensor
Place the tip of your finger on the fingerprint sensor to unlock your mobile phone.
3. The Volume key
Several functions are associated with the Volume key:
Press the upper or lower part of the Volume key to adjust the ring volume.
Press the upper or lower part of the Volume key during a call to adjust the volume.
Press the upper or lower part of the Volume key to silence the incoming call alert.
4. Socket
Connect the charger or data cable to the socket and to a wall socket or your computer's USB port.
Connect the headset to the socket to listen to music or make a handsfree call.
5. Camera lens at the back of your mobile phone
Point the camera lens at the back of your mobile phone at the required object to take a picture or record a video clip.
6. Camera lens at the front of your mobile phone
Point the camera lens at the front of your mobile phone at the required object to take a picture or record a video clip.
