Samsung Galaxy Note10+
Back to Settings & usage
Write and send MMS
An MMS is a message which can contain pictures and other media files and can be sent to other mobile phones and e-mail addresses. If you can't send and receive MMS as soon as you've inserted your SIM, you need to set up your mobile phone for MMS.
1. Open messages
Press the message icon.
2. Write MMS
Press the new message icon.
3. Select recipient
Press Recipient and key in the first letters of the required contact.
Press the required contact.
4. Write text
Press the text input field and write the text for your MMS.
5. Insert picture
Press arrow right.
Press the picture icon.
Press From Gallery and go to the required folder.
Press the required picture.
Press Done.
6. Send the MMS
Press the send icon when you've written your MMS.
7. Return to the Home screen
