Samsung Galaxy Note10+
Use your mobile phone as Wi-Fi hotspot
When you use your mobile phone as a Wi-Fi hotspot, you can share your mobile phone's Internet connection with other devices via WLAN. Remember, you need to set up your mobile phone for Internet. Depending on your price plan additional costs could arise.
1. Find "Mobile Hotspot"
Press Connections.
Press Mobile Hotspot and Tethering.
Press Mobile Hotspot.
Press the name of the Wi-Fi hotspot.
The password prevents others from accessing your Wi-Fi hotspot without your approval.
Key in the required name for the Wi-Fi hotspot and press Save.
To password protect your Wi-Fi hotspot, press Password.
Key in the required password and press Save.
3. Activate the Wi-Fi hotspot
Press the indicator below "Mobile Hotspot" to activate the function.
4. Establish a connection
Activate WLAN.
Activate WLAN.
5. Return to the Home screen
