Samsung Galaxy Note10+
Connect to a WLAN
1. Find "Wi-Fi"
Press Connections.
Press Wi-Fi.
2. Activate WLAN
Press the indicator below "Wi-Fi" until the function is activated.
3. Connect to a WLAN
Press the required WLAN.
Follow the instructions on the display to key in the security settings, if required, and press Connect.
4. Return to the Home screen
