Activate or deactivate WiFi Calling
When WiFi Calling is activated, you can make and receive voice calls over WLAN when you're in an area with poor or no network coverage. This service only works once you've received an SMS about Advanced Calling availability. Remember, you need to establish a connection to a WLAN.
Step 1 of 7
Press the phone icon.
Step 2 of 7
Press the menu icon.
Step 3 of 7
Press Settings.
Step 4 of 7
Press Wi-Fi Calling.
Step 5 of 7
Press the indicator below "Wi Fi Calling" to activate or deactivate the function.
Step 6 of 7
Press the required setting.
Step 7 of 7
1. Find "Settings"
Press Settings.
2. Activate or deactivate WiFi Calling
3. Return to the Home screen
Get information on...
Or select...
Another device
