Samsung Galaxy Note10+
Activate or deactivate mobile data
You can limit your data usage by deactivating mobile data. No connection to the Internet via the mobile network can then be established. You can still use WLAN even though mobile data is deactivated.
1. Activate or deactivate mobile data
Slide two fingers down the display.
Press the mobile data icon to activate or deactivate the function.
2. Return to the Home screen
