Activate or deactivate GPS
You mobile phone can determine your geographical position using GPS (Global Positioning System). The information about your position is used by a number of applications on your mobile phone, such as navigation, the search function and the weather forecast.
Step 1 of 9
Step 2 of 9
Step 3 of 9
Press Biometrics and security.
Step 4 of 9
Press Location.
Step 5 of 9
Press the indicator below "Location" to activate or deactivate the function.
Step 6 of 9
Press Google Location Accuracy.
Step 7 of 9
Press the indicator next to "Improve Location Accuracy" to activate the function. If you turn on the function, your mobile phone can find your exact position using the GPS satellites, the mobile network and nearby WLANs. Satellite-based GPS requires a clear view of the sky.
Step 8 of 9
Press the indicator next to "Improve Location Accuracy" to deactivate the function. If you turn off the function, your mobile phone can find your exact position but it may take longer as there is no access to supplementary information from the mobile network or nearby WLANs.
Step 9 of 9
1. Find "Location"
Press Location.
2. Activate or deactivate GPS
3. Select positioning method
4. Return to the Home screen
Get information on...
Or select...
Another device
