Samsung Galaxy Note 4
Insert SIM and battery
To start using your mobile phone, you need to insert your SIM and battery.
1. Remove the back cover
Turn the back of your mobile phone towards you.
Take hold of the left side of the back cover and remove it.
2. Insert your SIM
Place your SIM as illustrated below the SIM holder.
Slide your SIM into the holder.
3. Insert the battery
Place the battery in your mobile phone (top first), matching the battery contacts with the phone contacts, and press the battery into place.
4. Replace the back cover
Place the back cover on your mobile phone and press it into place.
