Mobile guides
Back to Select settings
Activate or deactivate mobile data
You can limit your data usage by deactivating mobile data. No connection to the Internet via the mobile network can then be established. You can still use WLAN even though mobile data is deactivated.
Step 1 of 2
Press Mobile data to activate or deactivate the function.
Step 2 of 2
1. Activate or deactivate mobile data
2. Return to the Home screen
Get information on...
Or select...
Another device
