Samsung Galaxy Note 4
Connect to a WLAN
1. Find " Wi-Fi"
Press Wi-Fi.
2. Activate WLAN
Press the indicator next to "Wi-Fi" until the function is activated.
3. Connect to WLAN
Press the required WLAN.
Press Connect.
Press Connect.
4. Return to the Home screen
