Customer Center E-Mail myCloud TV Network status Find a shop Contact
Mobile guides
Back to Select settings
Select a ring tone
Step 1 of 10
Step 2 of 10
Press the Device tab.
Step 3 of 10
Press Sound.
Step 4 of 10
Press Ringtones.
Step 5 of 10
To use one of the phone ring tones:
Step 6 of 10
Once you've found a ring tone you like, press OK.
Step 7 of 10
To use one of your own ring tones:
Press Add.
Step 8 of 10
Go to the required folder.
Step 9 of 10
Once you've found a ring tone you like, press Done.
Step 10 of 10
1. Find " Ringtones"
Press Sound.
Press Ringtones.
2. Select ring tone
Press Add.
3. Return to the Home screen
Get information on...
Or select...
Another device
