Back to Select settings
You can limit your data usage when abroad by deactivating data roaming. No connection to the Internet via the mobile network when abroad can then be established. You can still use WLAN even though data roaming is deactivated. Remember, you need to activate mobile data.
Step 1 of 7
Step 2 of 7
Press the Connections tab.
Step 3 of 7
Press More networks.
Step 4 of 7
Press Mobile networks.
Step 5 of 7
Step 6 of 7
If you activate data roaming:
Press OK to confirm.
Step 7 of 7
1. Find " Mobile networks"
3. Return to the Home screen
