Mobile guides
Back to Select settings
Select a ring tone
Step 1 of 9
Step 2 of 9
Press Sound.
Step 3 of 9
Press Ringtones.
Step 4 of 9
To use one of the phone ring tones:
Step 5 of 9
Once you've found a ring tone you like, press OK.
Step 6 of 9
To use one of your own ring tones:
Press Add.
Step 7 of 9
Go to the required folder.
Step 8 of 9
Once you've found a ring tone you like, press Done.
Step 9 of 9
1. Find " Ringtones"
Press Sound.
Press Ringtones.
2. Select ring tone
Press Add.
3. Return to the Home screen
