Customer Center E-Mail myCloud TV Network status Find a shop Contact
Mobile guides
Back to Select settings
Activate or deactivate mobile data
You can limit your data usage by deactivating mobile data. No connection to the Internet via the mobile network can then be established. You can still use WLAN even though mobile data is deactivated.
Step 1 of 3
Slide two fingers down the display starting from the top edge of your mobile phone.
Press Mobile data to activate or deactivate the function.
Step 2 of 3
If you deactivate the function:
Press OK.
Step 3 of 3
1. Activate or deactivate mobile data
Press OK.
2. Return to the Home screen
Get information on...
Or select...
Another device
