Back to Settings & usage
Connect a Bluetooth device to your mobile phone
Bluetooth is a wireless connection which you can use to transfer files between two devices or to establish a connection to other devices, such as a wireless headset or keyboard.
Step 1 of 7
Step 2 of 7
Step 3 of 7
Press Connections.
Step 4 of 7
Press Bluetooth.
Step 5 of 7
Press the indicator below "Bluetooth" until the function is activated.
Step 6 of 7
Press the required Bluetooth device and follow the instructions on the display to connect the Bluetooth device to your mobile phone.
Step 7 of 7
1. Find "Bluetooth"
Press Connections.
Press Bluetooth.
2. Activate Bluetooth
4. Return to the Home screen
Get information on...
Or select...
Another device
