Mobile guides
Back to Settings & usage
Step 1 of 16
Step 2 of 16
Step 3 of 16
Step 4 of 16
Press Fingerprint Scanner.
Step 5 of 16
Press CONTINUE.
Step 6 of 16
Step 7 of 16
Follow the instructions on the display to create the phone lock code using your fingerprint.
Step 8 of 16
Press DONE.
Step 9 of 16
Press the required setting.
Step 10 of 16
Press DONE.
Step 11 of 16
Press the return icon.
Step 12 of 16
Press Screen lock type.
Step 13 of 16
Key in the current phone lock code and press None.
Step 14 of 16
Press REMOVE DATA.
Step 15 of 16
Press REMOVE.
Step 16 of 16
1. Find "Lock screen and security"
2. Create phone lock code using your fingerprint
Press CONTINUE.
Press DONE.
Press DONE.
Press REMOVE DATA.
Press REMOVE.
4. Return to the Home screen
Get information on...
Or select...
Another device
