Mobile guides
Samsung Galaxy A7 (2018)
If the device memory is filled with apps, music, picture, video clips etc., this may be the reason why your device feels slow.
Solution: Uninstall apps or delete other content from the memory. You can also expand the memory by inserting a compatible memory card into your device if supported.
