Samsung Galaxy A5 (2016)
Back to Select settings
You can limit your data usage when abroad by deactivating data roaming. No connection to the Internet via the mobile network when abroad can then be established. You can still use WLAN even though data roaming is deactivated. Remember, you need to activate mobile data.
1. Find " Mobile networks"
Press Mobile networks.
If you activate the function:
Press OK.
Press OK.
3. Return to the Home screen
