Mobile guides
Insert SIM and battery
To start using your mobile phone, you need to insert your SIM and battery.
Step 1 of 5
Turn the back of your mobile phone towards you.
Take hold of the top left side of the back cover and remove it.
Step 2 of 5
Place your SIM as illustrated next to the SIM holder.
Step 3 of 5
Slide your SIM into the SIM holder.
Step 4 of 5
Place the battery in your mobile phone (top first), matching the battery contacts with the phone contacts, and press the battery into place.
Step 5 of 5
Place the back cover on your mobile phone, bottom first, and press it into place.
1. Remove the back cover
2. Insert your SIM
3. Insert the battery
4. Replace the back cover
