Mobile guides
Back to Select settings
Select a ring tone
Step 1 of 6
Slide your finger left on the display.
Press Settings.
Step 2 of 6
Press ringtones+sounds.
Step 3 of 6
Press the field below "Ringtone".
Step 4 of 6
Press the play icon next to the different ring tones to listen to them.
Step 5 of 6
Once you've found a ring tone you like, press the required ring tone.
Step 6 of 6
1. Find "ringtones+sounds"
Press Settings.
2. Select ring tone
3. Return to the Home screen
