Mobile guides
Back to Select settings
Activate or deactivate mobile data
You can avoid unintended data traffic by deactivating mobile data. No connection to the Internet via the mobile network can then be established. You can still use WLAN even though mobile data is deactivated.
Step 1 of 5
Slide your finger left on the display.
Press Settings.
Step 2 of 5
Press mobile network.
Step 3 of 5
Press the field below "Data connection".
Step 4 of 5
Press on or off.
Step 5 of 5
1. Find "mobile network"
Press Settings.
2. Activate or deactivate mobile data
Press on or off.
3. Return to the Home screen
